freakshoww1983
Newbie
I finally got my front drive shaft put back in my truck and decided to make sure everything was working as it should. I then heard a nasty metal on metal grind when I'd make a tight turn in 4 wheel. The grind sounded rotational, only happens in 4 wheel, and only on tight turns. You could also feel a bit of a ship when turning like the tires bouncing when you turn too tight. Asked the auto part store and they said u joint behind the tire and an auto repair shop said could be the hub are worn and the spline might be slipping. U joint would be cheaper to fix but hubs are easier. Any clue on how to determine which or what it is?
