joshthemule
So, when I steer my truck, there is a course grinding sound. I greased my spring caps, lower king pin, pitman arm ball joint and the tie rod ends. Still there are getting worse. Just started a few days ago. Seems like its comeing from the left wheel but I don't have a helper to steer while I listen. I figure its the lower kingpin bearing or the tie rod ball joint. I just installed crossover steering so the draglink, upper kingpin spring and bushing are all just a few months old.
Any suggestions?
Any suggestions?
