According to wire schematics there appears to be a ground wire junction block somewhere under the dash on square body Chevy's. My question is where is this junction block located under the dash?
My squares, 83 and 84 have a multi ground setup above the kick panel by parking brake.
x2 location its got 4-6 tabs on it if I recall.My squares, 83 and 84 have a multi ground setup above the kick panel by parking brake.
That "Ground wire Junction Block", I was referring to seems to actually be the Instrument Panel Connector, which is probably just the group of wire s coming out from behind the fuse panel.
FWIW the "IP" connector is the one on the back of the cluster. I'd have to double check, but pretty sure my ground block is above the pedal bracket too, attached directly to the body.
