Replaced the lift pump about a month ago and have been driving The Blazer semi-often since then. No more diesel on the ground under the pump's area.
However now I seem to have engine oil all over under the front output of the transfer case. The CV joint right there is COVERED with black oil. Thinking it must be wicking back from somewhere and ending up on it, then dripping off when it's stationary.
Looks like it needs new main seals and pan gaskets and probably even a pan as it seems to be leaking out around the dipstick tube.
Took it on a road trip this weekend. Drove great, no smoke, started/ran/turned off fine. However I believe it was about 212 miles round trip, mostly freeway at 70ish, and I used up slightly over half a tank. Ouch. Same mileage I was getting before the lift pump replacement.
Just bitchin'.
Just bitchin'.
