He thought he could make it. he'll have to explain.Ok, gotta ask, how did he get like that? Bad line? Was he trying to avoid going over what his front DS quarter is resting on? Curious now.
Even with that broke, he still had 4 wheel drive, and doesn't have to buy a new one.![]()
OK, scratching off Longfields off my list. Sticking with stock shafts.
he's already got 2 lined upOk i was gonna comment on the shifter cause it's like an optical illusion and i thought it was going through the steering wheel but i can see that it isn't and it's the spinner knob i see
EDIT: if i lived any closer i'd give him the cab i got. Minimal rust![]()
Bizarre on the longfield. Also bizarre is the 'A' pillar shear/break...unless it's been poorly repaired at some time in the past I can't see how it could or should have sheared like that.
Time for a cage IMO!
Rene
I was attempting to drive through that V up on the right side to AVOID cab damage! The sand was soft and had water running through it and the d-side tires kept digging down. FYI the Holley Truck Avenger carb was still keeping my engine running @ that angle - I ended up shutting it off due to no oil pressure for 5+ minutes!!
