H1 8 bolt wheels, need some parts
cybrfire
1 ton status
Iowa
H1 run flats, need 3 wheels worth.
H1 wheel studs, would like 40 of them including nuts
H1 O-rings, Need 3 of them wouldn't mind an extra or two.
Change your mind and use 12 bolts instead. I have a butt load of those in the shop.
I have put studs from 12-bolts in my 8-bolts. They just need a flat side ground on the head to fit - if that makes finding some easier. The best source is somebody scrapping out wheels. Buying all new hardware will cost more than the wheels. I think it's good to have extra studs and nuts, too. I lost probably 4 or 5 in the first year of having H1 wheels. Since then none have broken, but I still carry some.
I'll be home from my deployment by the weekend. Let me know if you still need the H1 parts. I have a good working relationship with my Battalion Motor Sgt. Im pretty confident I can get you all you need except the run flats. I couldnt tell you if they have any spares floating around. Its usually a one for one exchange on items like that.
I've taken care of most of it.
Would still like to have a handful of extra studs so if somebody has some they'd part with, 8 bolt style or 12, I'd be interested.
PM me if you want to strike up a deal.
thanks Guys!
