H1 double bead locks 24 bolt & BFG baha radials
chaoticK5
Hooper
I have for sale 4 37s and 24 bolt combo with rubber inserts all 4 look like the pick 800.$ trades welcome looking for chromo D60 shafts or doubler to go behind a 400 w/205 1-801-540-8011 location in ogden utah but travel to salt lake city often ,firm on price ,no junk for trade SOLD!!!!
How much is shipping for one tire/rim combo to 67439 zip?
I know, I know, I'll have to multiply by 4 to get the total.
I will ship if you set it up . Im close to a ups store 84401 zip .never shiped any thing like this
All you gotta do is measure the width and height of the tire/rim and then weigh it.
Call UPS and give them those specs with my zip code and they'll give you a quote.
If you can do it on www.ups.com site, that'll be quicker but I'm not sure they have the boxes for filling in the measurement sizes anymore. Only the weight. This won't be as accurate as calling it in instead.
Why not go ahead and get the true actual width, height and weight and I'll do it myself.
I think thay weigh 150ea+-10lb and 37in tall and 13in wide . will this get you in the ball park ? you might loose 30lb ea if i remove the runflat .
UPS showed $123 per tire/rim from SLC as they wouldn't list Ogden.
They also didn't ask for the measurements. Only the weight.
Need to call it in and ask them personally for a quote with the numbers supplied above. Their website isn't good enough. I'm gonna bet the quote will be lower than the $123 as the site showed.
Don't remove the runflat. That would defeat the whole purpose of this whole setup.
Would you strap 4 to a pallet and drop off at the Conway Truck Lines terminal in SLC?
yep I got a pallet ,no straping tool, Ill bet thay got one at conway ,just give me a call
i will chip in for some fuel if you happen to be coming this way. it doesnt look like you own any fuel efficient vehicles that can haul 5 tires in them.
maybe the 4runner. not sure how many 37s would fit
Suburban gets 12mpg, well it did before it got stuck in 4x4 not sure now, pretty sure I could get five in it.
So why don't we see more 24 bolt wheels show up? Were they on lower production vehicles for the military or are they the ones still in use and haven't hit the market yet?
The 24 bolts are newer, they started coming out 5 years ago or less. I've heard they went to 24s due to the increased weight on the up armored HMMWVs.
