pma4x4
AKA Yankeeroad
Ok, I know there have been some threads and articles on recentering a used H1 wheel and then using it on the street. Some have claimed no problem, most noticed a balance issue The thing is every thread and article I found on them whether at CK5 or else where the users had military take offs.
I am looking for input from people that have the recentered H1 wheels and have gone with a different tires like a BFG AT in 35x12.50x16.5” Or just anything else then the surplus tires and actually have driven this on the road extensively.
What have you done about balancing? I was looking at the Centramatics (http://centramatic.com/Home.aspx)
My plan was to get the 12 bolt H1s. Build a runout jig for the wheel, use the pressed recenter with the fixed backsapce of 3.5” get the TWB PVC beadlock pieces and call it a day.
If you are running such a setup can you post which H1 wheel 8, 12 or 24 bolt. which if any inner beadlock/runflat device and what tire.
