H1 wheel re-center question
45acpJr
Tucson, Az
What is the appropriate backspacing for the H! wheels? I am having the wheels recentered, the axles being used will be a 14 Bolt FF and a Dana 60 out of a 1 ton SRW K30. I believe it's 3.5" but I have seen mixed opinions. Thanks for the help
If they are 8 bolt 3.5 is pretty standard with a pressed center becuase it sits on the lip. You get more with a flat center about 4.25. If its a 12 bolt wheel they don't have the lip so its wherever you feel like putting it
Whatever you need it to be.
3.5" on up to 4.5" I would consider normal. Could be less, could be more. Really, what is correct is what you want or need it to be.
I have my pressed centers down on the lip. Don't think I would want any less bs.
