H2O temp gauge vs Trans temp gauge
AZ75K5
Arizona
Can a mechanical water temp gauge be used in place of a transmission temp gauge? It seems as though that would be possible. They are just a temp sensor attached to a gauge, right? As long as the degree scale is suitable, I think it would work. Any insight?
Sure, providing the sending units are the same. With aftermarket units you're prolly in good shape.
I took the ammeter out of my factory dash -- damn thing never worked anyway, and with triple batteries it'd be meaningless :D ... took a factory water temp gauge and put the ammeter dial face on it, and then plumbed a factory water temp sender inline with my tranny line.
Was it worth it? Donno. Cheap, but a LOT of effort, as opposed to the $50 you pay for the B&M kit from Summit.
-- A
That makes sense. Anyone else? I want to hurry up and get one ordered in
where do you put the sending unit for a trans temp guage do you just tee into the return line from the cooler or is there a different spot?
Also which do you all think is better mechanical or electrical?
I would splice the "T" into the cooler feed line (between tranny and cooler), because I want to know how much the transmission is heating the fluid...not how well the cooler is working. I think mechanical is the most simple set up on any rig thats not already equipped with all the electronics. Also, Im thinking you can use a mechanical water temp gauge (cheaper) in place of a tranny cooler gauge...but im still waiting for more response on this.
If you are talking after market mecnanical guages, then yes it will work. The sensor is for heat not for identification of the fluid it i placed in. Heck the same guage can measure a pot of beans on the stove, it really won't matter.
You mean like this ...
this was testing the resistance of the factory sender at different temperatures...
-- A
