HAD Parking Brake: NP205
t89blazer
Jackson, MS
High Angle Driveline parking brake setup for a NP205 (GM or Ford).
I bought the rotor a couple of years ago (used) and finally got around to piecing the rest of the kit together. The caliper and pads are new (never installed) and so is the bracket. Rotor has a little surface rust but no grooves or visable wear. The bolt pattern of the rotor is for the HAD flange but I think it could be drilled for a standard yoke.
Bought two rotors so I don't need this setup.
SOLD!!
If you are interested or have a question, post up or send me a PM.
Thanks,
Tim
The only thing that would have to be made is a bracket to hold your parking brake cable at or near the caliper. The lever for the caliper is built in. It is the black piece that is sticking out of the caliper. If you would like, I can take a series of pics this afternoon showing how the caliper works.
Let me know if you have any questions.
Thanks,
No Problem. I have not looked at his products much, so I was not aware that he had one.
Thanks for looking,
Tim
Yes, I am open to trades, but I did not see anything in that post that I need. Do you have anything else? I am looking for triple cable shifters, doubler adapter, etc.
Thanks for looking,
Tim
don't have much else needing to get rid of unless you are into snowmobile parts :)
Interested in this if you still have like next spring. $$$ priorities are getting the truggy running first.
No, not much use for snowmobile parts:wink1:. Hope I don't have it in the spring, but if I do, you are welcome to it.
Thanks,
Lots of views and PMs but no $$$, Make reasonable offers!! I have my eye on something else.
Thanks,
Have any more pics of this?
