So recently ive developed this annoying squeak that sounds like its coming from my tranny/torque converter area. Only happens when the truck is warm and,at idle, in gear It is not noticeable while driving. Did a breif inspection today, flexplate is ok, bolts ate tight. I need to get my wife out to put it in drive with the brake on so I can get under it.
Any wisdom on what this could be? It is quite annoying. Th350 anf I have an aftermarket sfi flexplate. Trans shifts great.
Anither problem I had maybe related was when I was out wheelin and on a sidehill slightly downard I couldnt get my truck out of drive. I ciuld go d 2 1 but wouldnt shift past nutral because it was acting bound up. Had to put the t case in nuetral and get winched backward a ways to flat ground then it worked again.
