Inu-Hanyou1776
What's wrong with using a bike brake handle? Why the need to use a bike's friction shifter?
Geargrinder said:I sold the last truck to a buddy of mine, if I get over there this weekend I'll snap a few of the set up.
Inu-Hanyou1776 said:...cause in any stick-shifted vehicle I drive I almost always wind up using the shifter as a hand rest while steering with the left hand at 12 o'clock.
just what i was thinkinbeater_k20 said:goodbye synchros...![]()
Sometimes you want the system to hold a particular setting w/o having your hand on the lever.Inu-Hanyou1776 said:What's wrong with using a bike brake handle? Why the need to use a bike's friction shifter?
ntsqd said:Sometimes you want the system to hold a particular setting w/o having your hand on the lever.
One way to semi-cheat this w/ and EFI system is to install a diode and a switch to tell the computer that the A/C is on when it really isn't. Not much adjustability, but it does raise the idle speed.
You can order those from mcmaster.com/. Search p/n 6059K4 Though you'll spend a bit more than the bike parts.3 on the tree said:My ambulance has a hand throttle. Its not meant for rapid changes, just setting higher rpms. Its a big red knob under the dash, just turn clockwise to raisespeed. Maybe look for some old ammbulances in junkyards, get the parts off one of them.
