I made the swap on my 89' from the 10 bolt rear to a 14SF rear. I replaced all of the brake components (springs, shoes, turned drums) as well as new wheel cylinders. I re-used my brake line from the 10 bolt and swapped it over.
The problem, when I now use the brakes, the pedal feels hard when I begin braking. The rears aren't exactly adjusted very tight but it just feels a little different now.
I Bled the rear and then front brakes with no change really. I tried a hard skid on the gravel yesterday and the rears are still locking up before the fronts.....and also confirmed this on the freeway offramp this morning. Decided to hit it kinda hard and the rears locked a bit and I felt the rear slide just a bit (indicating the fronts were't locking).
The front calipers, pads and rotors are all new about a year ago.
The only thing left is the master cylinder or booster.
I thought about just replacing the master cylinder/booster with a Autozone one but wanted to be sure there wasn't something else going on. The 14SF wheel cylinders are just a touch bigger in diameter than the 10 bolt but would it make it behave this way?
Just want to find the proper solution here.
