Taylor
Help me out guys! I have a 3/4 ton 97 Burb with a Vortec 454 that I'm having a hard start problem with.
Here is what it does, when I try to start it I turn it over for 5-10 seconds but it dosent fire, I turn the key off then crank it again for about another 5 seconds then it fires and there is a heavy raw fuel smell.
Another symptom it has when its in gear and at a stop it feels like there is a real slight hesitation, not enough to make the tach bounce but you can definitely feel it. I'm sure its related somehow.
This is what I have done so far:
-New plugs.
-New Batteries (then needed replaced anyway)
-Cleaned the contacts on the airflow sensor.
-Checked the fuel pressure, it runs at a steady 55psi.
Any ideas?
-New plugs.
Any ideas?
