Hard Top Gaskets and Seals
10pax
Ft Bragg, NC
Any ideas on the best place to buy gaskets and seals for the hard top on my 77'? I know of two places...LMC and Classic Parts... but here is the delima... The parts from Classic Parts seem to be the same price and cheaper on some, but how is the quality? I don't want to spend a fortune but would like some good stuff too. I beleive the age-old saying about "You get what you pay for." but in this hobby, that is not always true. Any ideas would be much appreciated. Thanx
James
If you do a little searching you may find that some have found that the dealer still has these available. That would be the best place, but is more expensive than LMC. Here are the two header seals:
Header seal inner - cab.................................15590455...... .....$57.65................LMC $29.95
Header seal outter - topper............................357490.......... .....$52.14...............LMC $29.95
These have the dealer price when Metrodps found them. They will need to be ordered in, but it is well worth the price for original.
x2. Buy from the dealer what you can.
I bought some of the top seals from LMC, three of them were made completely incorrectly, two so much that they were unusable and had to be returned.
Get the GM ones.. gmpartsdirect.com is cheaper than the dealer.
15590455 $37.52
357490 $33.91
Do a search.. Someone posted all of the part #'s for all the seals
15590455 $37.52
357490 $33.91
X2 I posted information on seals you can still get from GM Dealer.
So Friday I decieded to take a little trip to my local Chevy dealer. I thought I would see what seals were still available for the cab and topper on my Blazer. Here is a report on my little field trip. The numbers and first price is OEM the last price is LMC Truck. I ordered mine and most will be here Monday the rest will be here Wednesday. Also got better pics of the tail gate and door parts.
1973 -1991 Blazer/Jimmy
Door seal on cab body (LH&RH).......................15522764............$40.85...............LMC $29.95 x 2
Door to window seal outter............................14027775............$32.00...............LMC $19.95
Door to window seal outter............................14027776............$32.00...............LMC $19.95
Door to window seal inner.............................15569071............$32.00...............LMC $19.95
Door to window seal inner.............................15569072............$32.00...............LMC $19.95
Header seal inner - cab.................................15590455...........$57.65................LMC $29.95
Header seal outter - topper............................357490...............$52.14...............LMC $29.95
Lower side seal............................................358589...............$79.18...............LMC $29.95
Lower side seal............................................358590...............$79.18...............LMC $29.95
Tail gate weather strip...................................326934...............$77.20...............LMC $49.95
Tail gate window seal outter...........................327005...............$33.65...............LMC $29.95
Tail gate window seal inner............................327006...............$33.65...............LMC $29.95
This is my old refrence sheet so the item number is not the same as the new but you can use it for refrence. \/
There I went and found it for the LAZY people! :haha::haha::haha:
Thanx Guys
I have not had a chance to reply any to this. I am currently on my way home finally from Iraq after 15 mos. I should be home in a few days and will start getting these gaskets. Will reply again when I get home.
James
