wildweaselmi
Bra Stress Tester
Now fall is coming I wanted to put the hard top back on. I received my rubber seals from LMC and put the cab one on and the rails on but the outter seal I just not sure which way it’s suppose to go on.
Anyone have pictures of the outter seal and how it’s installed?
Attaching both sides of the seal (since one side has grooves/ridges) and the other side is smooth. Which way does the big side go? Towards the cab or towards the top? Something that should be so simple...
I’ve been trying to find pictures of removed tops to compare but no luck.
