MEPR said:And as far as off road i have seen em crab walk ot of ruts after getting stuck.
MEPR, you have confused Quadrasteer (a brand name) with some other form of 4-wheel steering. Probably a custom full-hydraulic setup. For the Q-steer to "crabwalk" means that front and rear wheels turn in phase. This is programmed to only happen at high speeds. At low speeds, the wheels turn out of phase to reduce turning radius (when the fronts turn left, the rears turn right). If all four wheels are spinning fast enough to "trick" the controller into turning in-phase, that is hardly "walking" out of ruts anyway.
