Has anyone tapped np203 range for drain plug?
14-Bolt
Oregon
Searched, but saw nothing, wanted to know if anyone else has done it. I don't know if I should go through boss or to the left of it, up through the center of the magnet? Its twice as thick at boss, I'll prob do it there, with same size as 205 plug. Was thinking would be nice to change fluid without using siphon or pulling pto cover.
I did that 20 years ago when i saw a 205 had one, I had to have one on my 203:dunno:
Should of mentioned its just range box, doing doubler. Did it in bottom of boss, worked great. Used a 1/2" x 14 Npt tap to match the np205. Should of used a tapered reamer before I tapped, but it can be done without. I can also add a sight tube if I want now. Beets trying to suck all the oil out with a pump, I don't know why everyone with a doubler hasn't done this.
