Like you all, I hate oil leaks!
4L80E with less then 50 miles on it.
Trans pan leaks, coming from the trans bolts & oil Temp Sensor. I understand that the gasket that came with the trans is designed to not overtighten the bolts.
I have a new Lube Locker gasket that I want to use?
Should I throw the Lube Locker gasket away and use one like the one I removed?
I need recommendations for a Tread Sealant for the Temp Sensor?
I want to apply Automatic Transmission Gasket Maker to the Lube Locker Gasket just for extra assurance against pan, & pan bolt leaks, but I understand I shouldn't need it with the new Lube Locker gasket that I want to use.
And what about the Temp Sensor?
What do you guys recommend for Thread Sealant?
I HATE LEAKS!!!!!
I HATE LEAKS!!!!!
