have a tranny, how do i know if its good or not?
muddybuddy
1 ton status
Northern, VA
i bought an auto tranny a while ago to swap into a truck, but dont know if i should rebuild it first or not. how can i tell just by looking at it if its good to go or needs a rebuild?
is the only way to find out by swapping it in and trying it out? i hope not cuz that would be a pita just to find out its toast
if it has the fluid in it and it wasn't just changed before you bought it, that could give you an idea.
Try finding a local tranny shop. Bowtieoverdrives said they would charge me a hours laber to stick it in there test truck and test drive it for me.
You won't be able to see the clutches and other internals unless you take it apart, unless you pan is full of clutch fragments :eek1:
haha i swear swapping this tranny in is going to end up costing so much money. with my luck its probably fried
You have to run it in order to see if its bad or not...... Putting a tranny in to test it isnt that big of a deal.....
