I have searched and am more confused than when I started searching, lol. OK, I just bought an 87 Suburban K20, TBI 350, SM465/NP208. It has a Tuff Country 4" spring lift front/rear, longer braided brake lines, raised steering arm on axle, appears to be stock pitman arm and drag link. I took this thing for a test drive today and it has a good amount of bump steer. I had my wife turn the steering wheel back and forth to see if things were worn out, ther are not. BUT it appears the drag link has a slight UPWARD (front to back) angle. Should I replace the raised steering arm with a stock one? What angle should I be shooting for at ride height sitting on level ground?
Thank You for any help you can give.
