xXamwxxXx
Registered Member
So I have an 83 k5 with a 350. The truck seemed to run great when I first got it but it sat for about a year or so prior. The problems Im having now are that when I start it it seems to start but the rpms immediately start slowing down and it will die. Also if I am backing up a hill it will stumble really bad when I can actually get it going. It will also stumble a little when I accelerate too. Once the rpms are up it goes good. when it idles it seems like its just going really slow and at some point there is oil dripping from the rear of the motor someplace, it drips down the starter but only when its on. This truck did not leak prior to these problems. The turning point was one day i was driving and there was some ruts in a field so i ran through them and kinda floored it. The next time I started the truck these problems started. So far i have sprayed carb cleaner and replaced the fuel filter thinking maybe i brought up some crap in flooring the truck, which i had not done prior. Any tips on which direction I should be headed wold be greatly appreciated since this truck is going to have to be my daily driver soon. Thanks in advance.
