cegusman
3/4 ton status
Motor has sat for 3 years, ran fine when pulled. Was locked up 3 days ago, finally got it to turn and running yesterday. Ran and idled for maybe 15 min, then went and did a few laps around my storage unit parking lot and a few donuts. After the donuts it died and would not start again, ran great for the time being. Ran maybe a totale of 25 mins. Today I added 5 more gallons to the tank to make sure I had fuel, reprimed it, got it to start by flooring it and cranking about 15 secs. Will run for about 5 sec then die. Then nothing again, have to reprime and it does the same thing 5 secs then dead.
Questions:
Air getting in the system somewhere?
I know my return lines are leaking at the injectors, could that cause a problem? Ordered new return lines today.
Plan on changing the fuel pump and replace all rubber lines this weekend. Could the injectors or injector pump be fubar from sitting so long?
Questions:
. Will try again tomarrow with a new starter.
