I'm running a 79 350 in my 85 k5. Carburated with what I beleive is a mild cam. (bought it this way) Had erratic idle so I set the idle mixture screws even and at 1.5 turns out to get a base line. Idle came around but when I hook up the vaccum gage it bounces violently from 5 -15. Cant get a smooth reading to fine tune the mixture screws. Truck runs ok but I also now have to floor it to start it. I took my vaccum pump and went through all the hoses hooked to carb and intake. When pumped down they all hold a constant reading. I dont know much about carbs or vaccum yet , just learning as I go. I figured the guys here would have some ideas
they may finally have a home.
The intake is a sqaure bore edelbrock, so that part matches at least. Will replace the gasket when I rebuild it of course. I want a new carb but I've spent $6000 on my kids 72 k5 in the last 4 months so it'll have to wait.
