First is there a spot weld under the the B pillar, just under these 2 bolt holes that I can't get too?, thought I could take out this whole panel and make some new ones at work. Are there tack welds too B pillar as it turns and makes the cubby hole?
Second having a hell of a time removing pass kick panel, wanted to remove it to blast whats behind there and repaint. Definetly not doing the othere side. Just going to cut out bottom and weld in a angled piece. Things I need to know to remove kick panel? I have a feeling they are spot welded to the A pillar from the back side. I know they can only be removed with rocker out but I should be able to have it loose with all the spot welds drilled.
Replacing rockers and outer floor peices with new from tabco. Fabbing rear cab floor, cab floor sides 12" wide, and bottom B pillar panels. On a 82 blazer
