Having trouble shifting from D to N, th350
bot0611
Chula Vista, Ca
First when i go to D i feel like something hits the cab underneath, U joints are good BTW
And now im having trouble shifting from D to Nm just in thoose gears the problems exists, feels like the shifter gets stuck or something, havent checked underneath but decided to post and see what turns up
It's possible that the t-case mount is bad causing the shifter to bind up. I would start by climbing under the truck while someone is inside shifting to see what is going on (don't forget to chock the wheels and or put the E-brake on before climbing under).
