Hay Dj's Technics 1200mk2, neumark dm3001, coffin case
58 apache
clarksville,Va home of the body bag
contact at [email protected] or call 434 374 0099. I have 2 technics 1200sl mkII turntables. the industry standard. both have scratch pads and work perfectly. one of the pop up lights dosnt work and the pitch slide light is out but the pitch adj works fine. easy repair. mixer works great. Odysey coffin case is in perfect shape and is very sturdy. I also have a scissor stand very heavy duty to support the tables. also included is 2 stanton grove master TII-sk needles. also have a light that goes in the mixer. havnt messed with them in a year and only light play prior to that 650 or best offer. NEED THIS GONE FIRST 500 GETS IT ALL
Technics 1200 mk2
Vibration Resistant Construction
A die-cast aluminum body, heavy rubber base, and a lack of unnecessary components or empty space allow the 1200MK2 to absorb unwanted vibrations that could otherwise interfere with the sound.
Ultra-Low-Speed Motor / Super-High Torque
The 1200MK2's ultra-low-speed motor and high torque (1.5kg/cm) allow for super quick start-ups (0.7 sec) and stops.
Quartz Locked Pitch Adjustment
Allows for accurate quartz-locked pitch adjustments throughout its 16 percent (+/-8) range.
Total Direct-Drive Accuracy
Instead of just spinning the platter, the classic Technics Direct-Drive system actually incorporates it into the motor, reducing the number of parts that can malfunction and making consistent, accurate speeds possible. It's a system that has been providing fast start-up times and unequalled responsiveness for over thirty years. Wow & flutter 0.01% WRMS,, rumble -78dB.
Type Quartz direct-drive (manual turntables)
Drive Method Direct-Drive
Motor Brushless DC motor
Turntable Platter Aluminum diecast
Diameter 13 5/64" (33.2cm)
Mass 3.74 lbs (1.7 kg)
Turntable Speeds 33-1/3 rpm, 45 rpm
Variable Range Pitch ±8%, ±16%
Starting Torque 1.3 lb-in (1.5 kg-cm)
Build-Up Characteristics 0.7s from standstill to 33-1/3 rpm
Braking System Electronic brake
Wow and Flutter 0.01% WRMS
0.025% WRMS (JIS C5521)
±0.035% peak (IEC 98A Weighted}
Rumble -56dB (IEC 98A Unweighted)
-78dB (IEC Weighted)
Effective Length 9-1/16" (230mm)
Arm Height Adjustment Range 0-6mm
Overhang 19/32" (15mm)
Effective Mass 12g (without cartridge)
Offset Angle 22°
Friction Less than 7mg (lateral, vertical)
Tracking Error Angle Within 2° 32' (at the outer groove of 12" record)
Within 0° 32' (at the inner groove of 12" record)
Stylus Pressure Adjustment Range 0-4g
Applicable Cartridge Weight Range 3.5g - 13g
11g - 20.5g (including headshell)
Applicable Cartridge Weight Range (with auxiliary weight) 9.5g - 13g
17g - 20.5g (including headshell)
Applicable Cartridge Weight Range (with shell weight) 3.5g - 6.5g
11g - 14g (including head shell)
Headshell Weight 7.5g
Power Supply AC120V, 60Hz
Power Consumption 13.5W
Dimensions 17-27/32" x 6-25/32" x 13-31/32"
Weight 26.5lb (12 kg)
Numark dm3001x
Inputs: 3 phono, 3 line, 1 mic w/ EQ
Outputs: master, booth, record, PFL cue send for sampling
Bass, middle, and treble KILL switches
Unique punch IN/OUT transform buttons, panning
Channels contain: gain, 3-band rotary EQ
Assignable crossfader w/ “hamster” and slope adjust
