hd drag links?
easttxryda64
Registered Member
commerce tx
my steering has some slop in it that i'm in the process of fixing.. I know I going to need to replace the drag link. I just finished putting on my ORD HD tie rod, and it is nice! anyways instead of just replacing the drag link with regular replacement parts is there anyone that makes a HD kit for our drag links? BTw its a 1991 k5 , with normal push-pull steering (dont ever plan on needing x over)
The aftermarket drop draglinks are a little heavier duty but the stock really isn't a weak link
I broke a d44 knuckle with an old worn out draglink. I did bend the adjusting sleeve very slighty that night too. The adjusting sleeve is really the only thing that could be improved, the ends are really damn tough. I use oem ES2026R on my draglink with crossover and was rock crawling with 17" wide 40s without assist until I broke the frame, the ends are still fine.
