HD Shackels
kgblazerfive
keymaster
Hooper, Utah 84315
Hey have a question kind or dumb but, If I use the new HD shackels on a four inch shackel flip will it give me 2 more or only 1 more inch of lift? I'm reffering to the six inch longer ones. Oh nother question could these also be used to lower a truck?
We typically don't recommend using the 6" shackles with a 4" flip since you put the back of the spring way lower than the front. Depending on shackle angle, it can work, but not all the time. Usually the 2.5 flip with the 6" shackle is the way to go.
Lift wise, the 6" shackle will give you about 1" of lift since it's 2" length. This does depend somewhat on the shackle angle.
A 6" shackle in a stock tension shackle system will lower the vehicle about 1".
hey stephen, how much would it cost me if i wanted a pair of 7.5" long shackles to use with your 4" shackle flip. i have some home(hacked together)made shackles and they are the perfect length but i want something that is professionally made. what do you say?
Sounds like you're a perfect candidate for our build it yourself kit. We have the parts to let you build your own tube style shackles at any length you want, the folded style are more of a production piece.
The "kit" I'm referring to is the collection of parts we used to build the HD rear shackles on the UAK10, it's a HD bushing assembly, length of heavy wall tube and a u-shaped spring hanger bracket, pricing is $68.00 for the pair, you cut to length and weld together.
