hillbilly deluxe
Professional Pile-It
I have a '96 6.5 TD Suburban. It has 213k on it. I have a Heath Diesel computer and it runs really good. It has been leaking coolant for about 6 months now. I need to put in about a half gallon of coolant a month. It just makes a little puddle each time I park it for a while. I thought it was just a lower hose and I would get after it eventually. But here's what I noticed:
The cooling system is always pressured up. I expect that when its's hot, but I can park it overnight and come out in the morning and still relieve a bunch of pressure from the cap.
If I bleed the pressure off the system through the cap when I park it at night it stays bled off when I check in the morning.
I can't see how thermal expansion explains any of this. Seems like it must be getting pressure from the combustion chamber.
I've never seen any indication of coolant in the oil which I change every 3k.
Thoughts from the more experienced 6.x owners?
