Okay so I just picked up a 1982 6.2L K5 Blazer and I got a great deal on the truck because of a few minor issues that have turned into a few major issues. I need to totally replace the wiring (almost the whole harness). I also have been having a hell of a time trying to figure out what was causing my starter bolts to become loose to the point of falling out? I decided to check my glow plugs to see if any were bad, turns out 6 of 8 were bad. If anyone has any other tips on what could be causing the bolts to come lose please let me know... So now the big problem I noticed a lot of white smoke coming from my exhaust and after finding my oil mixed with quite a bit of coolant I have figured out I have a blown head gasket so this weekend I am going to start my first head gasket job. From what I have learned this truck is one of the easier engines to do a replacement. I have ordered a full gasket set every gasket above the head gasket will be replaced. So what Im looking for is maybe some tips from someone who has done this before and maybe some special tools I may need to complete the job. and also how I can clean up the heads once I get them removed. Can I use the soft wire attachment I have for my Dewalt drill? Basically I would love any helpful tips you have to offer.
Thank You,
Jeremy
Thank You,
Jeremy
