Head gasket?
slyguy_22
Lancaster, PA
Think i may have blown a head gasket. Seems to miss and sputter when im not on the throttle. and sometimes under load it will just die out and comeback on. i replaced plugs wires dist. cap & rotor. havent had a chance to run a compression test yet. but it dosent seem like its using coolant? every head gasket leak ive come across they used coolant. oil looks fine. has me alil confused. has lots of power at wot, just miss at idle and cuts out once and a while (never acctually shuts off it just cuts out for a split second then kicks back in) Any thoughts would be much appreciated. Im gona do a comp. test sometime this week if i get a chance.
blown head gaskets don't ALWAYS cause coolant leaks. being a tbi setup, i'd look at the electronic side of things closely before messing around with pulling heads.
Yeah someone else mentioned that too. im gona still check the comp. but im def gona check the ignition module (there only $30-35) so ill probly just grab a new one and plug it in and see if it helps any.
Thanks for the info
check compression before spending money
Often, you may have a leak in the gasket over the thinnest part of the wall between two cylinders. When that happens, you'll get a loss of compression in either of the two during the power and compression strokes, with a resultant blow-by in the adjacent cylinder at inappropriate times (e.g., during intake). So the compression test is the best way to determine that there is a problem.
However, it will not tell you what the problem is or where it's located exactly. You could have a bad spring on a valve, a stuck or burned valve, bad rings on a piston, etc.
Here's a quick and simple method to help identify and locate the problem: take the plug wires off the plugs, one at a time (best to have the engine off when you do that so your long hair and necktie don't get sucked into the fan, and your pacemaker doesn't get zapped by the current; at least use something with some insulation on it to do the r&r) until you find a difference in how things sound (i.e., smoother, but consistent with one cylinder not firing). Then take out the plug that made the difference and squirt a little gear oil, lucas oil additive, stp, or other thick gooey oil stuff (to use the technical terms) into that hole, put the plug in, and reconnect the wire - if that helps, you've got bad rings.
If it is a problem between two adjacent cylinders, then removing a single plug wire will ease the problem, but it won't tell you which side of that cylinder the hole in the gasket is on.
But my strong suggestion is that you check the compression before spending any more money.
