Head Gasket
blazinbg
Registered Member
california
So after posting here for some help found out I have a Blown head gasket. Since I wont be doing the repair myself , waht is the going rate for this type of repair? And also what types of scenarios might I encounter. Any help would be great.
You're going to need to start by telling us the year, make, and model and what engine. Then we'll need to know if the rig is stock or lifted. Most shops charge more if the rig is lifted as it is harder to work on. I'm going to guess if you only need to pull one head just the R&R labor is going to be close to 600.00 plus any work that needs to be farmed out for cleaning and resurfacing of the head. You could potentially end up having a cracked head which would be your worse case scenerio.
