He is talking about cutting a 5" (maby) piece of pipe to install in side your header. so that when you mount your exhaust up the exhaust gases will bypass the seal and go right into your exhaust.......Hey thats a new one a pipe within a pipe hahah. Good idea though
That is exactly what i'm talking about.
I only wish I could find a solution that good at the other end of the headers...
I haven't had a collector leak since I switched to aluminum gaskets about 2 years ago. I've had that interface apart a few times, too. They're about $15 from Summit. I only wish I could find a solution that good at the other end of the headers...
Same here. I switched to the super soft aluminum gaskets, and have had no leaks. My O2 sensor is mounted at the collector, so I had to elimimate all leaks. So far so good.
i just went to the performance section at my local parts store.i think i just used longer bolts on the engine side on the head.the collector bolts were long enuf to work.deopending on how long yours have been on there,they sometimes break because of rust and corrosion when you try and take them out to replace the gasket.got any part numbers for the alum. gaskets? I will try them. Sounds like a lot less mess and easier to assemble and disassemble.
