header options for 99 2500 5.7 vortec
twoslo4five0
3/4 ton status
Living in a dump, VA
im putting headers on my 1999 2500 soon.my manifolds are warped.here is the deal.i have a set off a k5 will they work on the 99?i know the bungs are not there for egr or for o2 sensors but thats a easy fix.i ask cause every header i find is 300 dollars and up.also im looking to do long tubes and thats why the price is so high.
you dont even have 24hrs and its a 99 truck what do you expect brother. ?
the frames are totaly diffrent and in the end i bet you would need to mod the older ones tu much to out way the price of bolt in and go. and the newer trucks do just fine with shorty headers. and those trucks in the 2500-3500 with factory duel exaust have 2.5" pipes from the manifolds back so flow is not a big problem.
im getting long tubes.the shortys give no real benifits via many people ive talked to.i figured you would chime in with help.i guess i can canibalize my exhaust so i can run true duals.thanks man
