Ok guys, I did my 53 inch alcan spring swap and moved my shackle mounts back and up some...that gets into clearance on my ball flange 3 inch collector (long tube headmans) I have a few ideas on what to do, but could use some help on this...
1.. Turn the collector and grind the side so it doesnt rub, then heat up the headers with the torch and ease them over toward the trans some.
2.. Cut off the collector, weld a sleave to it and slide my exhaust into it. I would leave it long so if i ever have to pull it apart there is plenty of pipe left. (not a real good idea in my mind but good for clearance.
3.. Cut off the collector and buy the clamps that go around the pipe to connect them togeather. ( clamp looks like pipe with bolts that squeezes the pipe)
4.. Buy shorty headers, only thing is mine are 2 years old and were 300.00.
Let me know any ideas, i gota do this before i wheel and the nice weathers here.....
