Been looking around for a while... Haven't found much...
Have an '88 Blazer with TBI 350. I have to have the Stock air injection/ smog pump because the truck has a manual trans. None of the other trucks Ive owned from this era have had air systems with the injection (all were auto trannies). My new motor is going together, and would really like a set of headers, but the only ones I see are the "tubular exhaust systems" that fit in place of the factory manifold, and they are all for trucks without air injection. I need to find a set of headers that will come with both an exemption sticker (so that I can at least attempt to pass smog), and provisions for the air injection system. I DO NOT HAVE AIR INJECTION FITTINGS ON EVERY EXHAUST PORT (like most of the older setups). I ONLY HAVE ONE FITTING AT THE FRONT OF EACH MANIFOLD (no 1 @ 2 cyls).
Does anybody make such a contraption? I seem to remember seeing a summit part # for the same year truck, but the trucks of that year changed to the newer body style, so not sure if it would fit... And not sure if a summit brand header is going to be any kind of quality I find acceptable.
Any thoughts or help would be great.
