vdubnut
Registered Member
Last week I went did part of a tune up on the burb....
i bought a set of A C Delco plugs and went to installing them.
On cylinder 5 i pulled off the boot only to find that the head of the wire was mostly cracked and burnt off. So i went back to Checker to get a set of wires. (the ones i had were some MSD's probably 10 yrs old) I went with the cheapo's since i figured that even cheap wires were better than the old cracked ones i had on there and i hadnt planned on doing wires.
So this weekend while towing my trailer on our camping trip, two of the wires basically burned to a crisp.
My question is this.... if you have aftermarket headers do you have to buy special high temp wires? I did my best to make sure no wires were touching the header pipes but you never know what happens while you're driving. do the cheap wires just melt? the other 6 cylinders wires look ok so far....might i have certain cylinders getting super hot?
thanks
jamie.
thanks
jamie.
