headers shorty style sbc
sweetk30
Back to play nice .
in the back of your brain
what ya got for a set of shorty headers for sbc ? i am looking for some for my 87 tbi setup. if no o2 bung no problem i can work around that.
not looking for long tube headers just shorty thanks.
There are collectors available with the O2 built in.
My Blazer had a set of long tubes on when I bought it. Haven't seen anything about them I like :mad:
There's another thread on headman coated headers that fit, last, clear oil filter and don't hang lower than the springs...
I used the shorty headers for the 88-95 body and all you have to do is plug the factory O2 sensor hole with a drain plug or weld it shut then install an O2 bung in the exhaust pipe just below the collector. You will have to grind about a 1/4" of frame rail in the location where the factory O2 sensor would have come out and hit the frame rail. The headers i have are Flowtech brand and you can get them from summit racing for 219.95. http://store.summitracing.com/partdetail.asp?autofilter=1&part=BIG%2D91830FLT&N=700+4294908216+4294840140+4294924930+4294908015+115&autoview=sku
thanks for the heads up 4x4high. if you got anymore good info check out my motor build in the tbi section. i got a list of parts going in and could use a trained eye like yours.
