I have a set of Flowtech Afterburners, supposed to give the HP of Tri-Y but the bottom end of long tubes, I can't really compare though, I imagine the HP difference between regular long tubes is not going to be felt in my butt.
We have Doug Thorleys on our 97 Suburban, very nice headers!
Some long tube headers might interfere with the frame. shorties are just as good and go in to with no clearance issues. I was actually lookin into a set of thorley tr-y's but after comin across enough folks I decided on shorties. Ask around and see what other guys have found for clearance problems.
I have a lot of clearance problems with long tube headers on my 1985 K30 Dually. The problem is on the right side. The right side header is only 1" away from the starter motor and wires. It is a nightmare to deal with the battery cable, heat shield, and wires going to the starter motor. The upper shock mount on the right side is completely obstructed by the header, and I had to make a custom heat shield for the fuel lines along the frame because it kept getting vapor lock from the heat of the headers.
I have a set of Doug Thorley Tri-Y headers, and they are really good headers, but they are a major hassle. Since this truck is street and trail driven only, and not a full-on dragster, the difference between long tube and short will probably not even be noticed, which is why I am seriously considering changing to a set of shorties.
