Headlight adjuster "clips"
4X4HIGH
1 ton status
Fremont, CA.
Does anyone have a part number or know where to source the little plastic headlight adjuster "clips" for an 89-91 Blazer? I'm talking about the little threaded plastics "clips" that snap into the core support and the adjuster screws thread into them. These clips are not the same for earlier years (I've tried).
I got mine from rock auto.
I will see if I can find a part number for you.
But they were the cheapest even with the shipping.
Yeah if you can find a part number that would be great, I looked on the website but couldn't find anything. I would imagine them to be listed under the Body heading but no luck.
Thanks guys, after reading through the thread skunked posted I ordered part number 15722032 last night and should arrive in a few days. They even had a "see if this fits your vehicle" and it shows it does so we shall see.
I just recently went through this also. The ones I picked up from the parts store absolutely awful. Stripped as soon as you put any pressure on them to adjust the headlights. Purchased the ones thru LMC, worked like a champ.
Not sure what year yours is but guessing 1977 from your screen name, mine is an 89 and the headlight adjusters only fit 89-91 for my year. I ordered a pack of 5 from a dealer and should get them next week hopefully.
From a dealer should be fine then. I only mentioned this because the parts store brands I tried were junk...I also have an '88 Jimmy.:saweet:
Your 88 Jimmy is different but yeah I would hope the dealer parts would be good especially since there is NO aftermarket for the 89-91 adjusters.
I’m guessing part 7 is what you want.
Is that $7.95 for one though? If so the factory ones I posted about in that other thread were $11 something a piece. I don't know if they are better than the LMC ones, kind of assuming they are. Id spend the extra money for the factory ones over the LMC ones. Wish I had done that to begin with compared to the Dormans, which I knew they would be cheap but took a chance. They fit fine but they are a phillips head adjustment screw and they stripped almost immediately when I got the others in and replaced them on the passenger side. I also ended up transferring them from my 89 to my 90 Suburban and the ones that didnt strip out on the 89 ended up stripping or trying to strip on the 90 when I put them on it.
I want to just order them through the dealer I believe. "Hopefully" they will be better.
The pricing was each and are sold in packs of 5 so you must add the pricing for 5 to get package pricing.
