badmix
I didnt want to hi-jack the other thread. I got my part in today. It required 3/32 rivets, which after some looking, I wouldve had to order. I had some 1/8" rivets and just drilled the lil holes out on the "floating nut" to 1/8" , worked like a charm.
got one side all mounted up and headlights in, seems pretty sturdy. Time will tell, but this has to be better than those POS plastic pieces from the factory.
The floating nut, its 1.23" long and the holes are 1" spaced. they fit perfectly in the space of the plastic square adjuster.
I have to pick up a couple of the adjuster screws and then I can install the drivers side lights, but that wont take any time, the mounts are already drilled and riveted onto the rad. support.
Thanks for looking
Thanks for looking
