Headlight adjustment on 80 K5
The1980BEAST
Ft.Worth Tx
Just put new 35" meats on her and the lights need to be adjusted down again.. problem being I can't rember for the life of me how to do it. I did it when I put the 3" lift on it but now I can't remeber..
Your help is appreciated
Up and down adjustment screws are on the topside of the headlight, side to side adjustment screws are on either both insides or both outsides. There should be a little recess in the trim rim/bezel where the screws are.
is it just tighten to raise level and loosen to lower, or would it be loosen to adjust then tighten back up?
