Mutt's an 89 with the same quad setup.. I'm probably just gonna throw some silverstars and do the relays in it... the K5 had a beefed relay setup and the LMC conversion kits and they worked killer....
H4 conversion just means that the outer glass/enclosure looks the same and mounts in the same spot. The H4's are standard and you have to rewire everything. For my year, the connector to my old headlights will connect to an H4, but I can't remember if the wiring is correct. I redid it anyway since the wire was old and too small.
The application chart says it'll fit your 89 Blazer.
Those ebay housings look interesting, the newer bulbs do seem to be much better in terms of brightness (but only when the plastic housings aren't clouded from UV!), as long as you used GOOD wiring with them, I would think they might work well.
Then again, at least on my car, the bulbs are almost water-tight due to the seals used, and as much water gets thrown around under the hood on these trucks, I'd probably want to see what the back of those housings looks like first. I'm assuming that water on the bulb would lead to instant failure? I know oil from skin will cause them to fail, guessing water would be bad when they were hot.
When modifying the existing wiring setup with relays, etc., any reason you didn't set them up to use the same bulbs on the bottom? 4 lows, 4 highs? That is my intent unless something changes my mind before I get around to it.
Rather then using relays would it be sufficient alone if I increase the gauge of the wire?
