headlight measurement from guys with 40s
blazinzuk
Buzzbox voodoo
Rexburg Idaho
So my suspension used to consist of the same spring (Superlift 5.5" superlift springs) all the way around. Well I finally got around to lowering it by using stock Dodge springs (they are the rears from a 95)
My question is two part, How much lift do you have (assuming you are running 39.5s) and what is your headlight heigth measured to the center of the headlight. I only messed around with the front suspension
Thanks guys I beleive I am now in the low lift big tire club :D
I took all of these measurements on the drivers side. It has a noticeable lean to the DS from the springs being beat on for so many years, but the PS was parked up on the curb.
Center of headlight = 50.25"
Top of door handle = 59"
Top of brake light = 50.25"
Lift is about 6" all around. 39.5" Biased Iroks on H1 beadlocks.
