SLO C5
The low beam, driver's side headlight is out on my 89 Sub, it has the dual horizontal headlights. All of the other lights on the driver's side harness work fine, the front and side markers/turn signals, and the high beam work as they should. I went over to Kragen and got the replacement halogen lamp, $12.99, and installed it. Still nothing.
I pulled back the wrapping on the wire harness a few inches from the light socket to see if the wires were damaged, but everything looked OK.
Also, what is that ~4" diameter canister tank thing up by the driver's side headlights? It has a line in it that goes near the power steering pump, and one that goes into the throttle body area.
