just a fresh thread on this with cheep parts and it works.
junkyard 88-95 chevy trucks a/c control relays behind glove box 4 phillips screws or 7-8 mm bolts.
then 2 screws or bolts to hold 3 relay bank some have 4 on them off the a/c box. some have 4 wires in pigtail others have 5. so if you want 5 wire pigtails look for them and dont be mad when you get home with 4.
cut pig tails with 4-6 " of wires on them. ( pic #1 )
then take home and remove bracket from relays and bend 3 mounting tabs back flat . ( pic #2 ) and then take 2 self tap screws and mount on fender next to washer bottle location. ( pic #3 )
open up wiring harnness and pull tan and green wires out for low/high beam power. cut and add 1 to each relay .
then add auto reset braker inline from alt power with big wire to feed relays.
ya there is a few things i left out but if you want full details look here in the orignal thread. http://coloradok5.com/forums/showthread.php?t=45681&highlight=relay+mod
and i did all this for under 20 bucks with junkyard relays and bracket . had to buy ends and braker.
also i have 4 relays 2 extra for my snow plow lights on the truck.
