Headlight weirdness
k20
3/4 ton status
Mineral Springs, NC
Ok guys, weird problem I found yesterday. I turn on my headlights, and they dont turn on, leave the switch on and then will come on after..... 30 seconds or so. I have all the marker/running/dash lights. If I rotate the switch the dome light will come on.
I have the relay mod done using 2 relays and I even switched the relays around and still nothing. If I click the hi-lo switch, when the headlights are still 'warming up' they will all come on. But if I click back to low beam, nothin. So basically I have hibeams but no lowbeams until they decide to click on.
What gives?
Oh yeh, once they switch on they are good for a few turn on/off's. Like last night once they clicked on, I had to run in the store for a few mins, turned the lights off, came back out and they came right back on like normal.
Just figured out what the problem was, I had a stressed fuse and a loose connection on one of the relay power feeds.
