Found Headlight wiring harness for 88-91 Blazer/Burb/1-Ton Truck
0331King
Registered Member
Between The Lakes
Whoever swapped out the front end on my 82 butchered the wiring and I want to make it right. Mine is the 4 light style.
'88 is different than '89-'91
The bulkhead connector on '89-'91 is like a GMT400, that's why it was "butchered".
So, even if you get a different harness, you are going to have to modify it.
Martin
I bought one with a late bulkhead but stacked dual headlights from a dude named jabin wood.
He can make you the opposite. Quality is worth the wait.
Martin
Yes, I am aware that the bulk heads are different. The problem I have is there is nothing resembling a harness going to the front signal and headlights. Only loose wires and spade connectors.
